Invite users to certain categories/topics of a closed forum
Hi,
we are running a strictly closed forum for a team, not a public forum. Now we would like to be able to invite “outsiders” to collaborate with us on certain topics (or maybe a whole category) without giving them access to the rest of the forums.
Is there an easy way to do this? Can someone be invited to a topic and then only see that topic and nothing else?
Giving access to a category is easy, I know how I would have to do that, but it’s not exactly what I am looking for.
Any ideas? Thoughts?
Thanks :slight_smile:
There are no permissions at the topic level. You could make a topic unlisted in a public category.
إعجاب واحد (1)
Or create a group and use a Group Message
إعجابَين (2)
Sorry for my ignorance, but how do you use a group message?
One more question:
While having a closed forum (invite only, no registration), is it still possible to have a public section that’s visible to any visitor? Say I want a public Wiki section where we post FAQs for customers while keeping the rest of the forum private?
No it’s not. It’s all or nothing.
So I couldn’t set up a category and change it’s security setting to allow “everyone” read permissions? Everyone in that case would mean every registered user? No anonymous access possible?
If you enable “login required”, then absolutely nothing will be available to the public. One thing that might work for you is:
  • Make all your categories accessible only to people in a certain group, e.g. “team”
  • Add all of your staff to the “team” group
  • Disable “login required”
  • Make a single “FAQ” category which is readable publically
You’ll have to be very careful when creating a post/category that it ends up with the correct permissions, but it might be workable.
إعجابَين (2)
Thanks David, appreciate it :slight_smile:
We already have all categories set up in a way that they are only accessible to certain groups.
If we disable “loin required” that would open up the forum for anonymous access then? And those users would see everything that is not locked down to specific group access?
Yes, that sounds correct to me
إعجاب واحد (1)
تم إغلاق هذا الموضوع تلقائيًا بعد 2525 يومًا. لم يعد الرد على المواضيع الجديدة مسموحًا به.
