Is it possible to make posts invisible to someone?
the current setting for preferences > Users > Ignored/Muted.
it is for someone to ignore/mute others’ posts,
say, user A, could ignore the posts from B. it is kind of an one-way blocking.
is it possible to do two-way blocking? set posts not visible to other specified users ?
say, user A does not want his/her posts to be seen by B.
or disallow B to comment on A’s posts.
wonder if this is in the plan, discussed, and if there is plugin for this function ?
thanks…
It’s not something that’s currently possible, but there is an open Contribute > Feature request for this you can add your use case too:
