האם יש אפשרות להפעיל הנחיה להנחיות עבור הפוסטים הראשונים של משתמש?
I did some searching and am not seeming to find what I hope I can configure
the nature of the community I am creating is sensitive and I would like to set a reminder to trigger before posting.
I experienced something similar in a reddit subreddit.
You could modify the text in admin/customize/text for education.new-topic and education.new-reply. This shows up in the first two posts the user creates so you could have it there as a reference.
Hi @cezzitall_oasis. :wave:
You might use one of the options listed at Creating a banner to display at the top of your site. :slight_smile:
ah okay
thanks
another good suggestion.
thank you.
This Customization > Theme component allows you to replace the watermark you first see about posting with something custom.
Here is a screenshot I used it in a category where people would often devolve in from time to time
