Problem beim Hinzufügen von Tags
has happened a few times…
trying to add a 3-character tag and i can’t seem to do it. the “create new tag” doesn’t always show up.
That’s odd. Any consistency to when you can’t create a 3 letter tag? It works here on Meta when I try…
1 „Gefällt mir“
i’ve had this issue a few times. ill give it another go… and see if it happens again in a way that reproducible.
A thought, which I don’t think I can test here on Meta, we don’t have enough similarly spelled tags - does it occur every time there are 5 existing tags that match the 3 letters?
1 „Gefällt mir“
I’m pushing updates to this component next week, might improve this.
4 „Gefällt mir“
tried a few more times… had another issue.
couldn’t seem to add a new tag… women… the problem is that this tag already exists:
so, i published the post and then went back to edit the tag and add it post-publish… but then it showed me this strange view:
now it says i could create a new one even though it found it.
strange.
Yes I know about the last one, it’s kind of an edge case. And a little bit annoying cause the list of existing tags is async so I’ m not sure what kind of UI I should do here. As I don’t want to remove the field as you are typing if the list shows an existing tag.
For the first one I will check.
1 „Gefällt mir“
Will be fixed by:
https://github.com/discourse/discourse/commit/410b90dde0d2a6382cc1425dd644147d2b55e420
Thanks
3 „Gefällt mir“
cool. had it happen again:
couldn’t create “gamengine”… but, i deleted it and typed in “gameengine” (two e’s) and then i could create.
and again.
I just pushed two fixes:
https://github.com/discourse/discourse/commit/9b680fc45c6540b65dcab6b4801b8e2322309c2a
https://github.com/discourse/discourse/commit/ba2f01c0bd7253dd8f1970c01e0876634803fe61
This should for sure fix this one:
Concerning the other issue, I would appreciate a more detailed reproduction.
6 „Gefällt mir“
kk. will continue to test post-update.
tried multiple times. showed “create” but disappeared when i got beyond “community” in the tag “ethereumcommunityfund”.
What’s your max tag length site setting? I bet “ethereumcommunityfund” is too long
2 „Gefällt mir“
a few more issues.
max tag length is 20.
There was still a case where it could happen indeed:
https://github.com/discourse/discourse/commit/5e323139aeefa445aa5b46ac55d57ffb883a95b3
6 „Gefällt mir“
This topic was automatically closed after 2 days. New replies are no longer allowed.
