JIRA Service Desk integration?
The question was already asked once, but not answered. Maybe this time someone knows about it.
In my vision we have a partner / customer forum which may not be necessarily publicly available. Within this closed community I thought about letting customers create a JIRA Service Desk ticket right out of a forum discussion. Anything like that possible or planned?
This is pretty much the same as your SalesForce question. If you can get Discourse to use the same SSO master, you should be fine.
Attached my Salesforce question: https://meta.discourse.org/t/salesforce-integration-in-closed-community/72763/2
Well then I’ll see first if I understand it for Salesforce and I will see how far I can go then for JIRA Service Desk if it basically based on the same principle.
As I just discussed the same in a different forum I thought I give you some further insight about my idea:
I am looking for a solution that also allows to directly create a support ticket out of a forum discussion. The community should try to help themselves, however if necessary they should be able to directly trigger a support case out of the discussion.
A ticket should be created and the support staff be notified about that (which is already business of the ticketing software). However, he/she should be able to quickly jump to the link of the discussion as well.
I assume this is a bi-directional integration and I am interested specifically if something like that exists for JIRA Service Desk or Zendesk Support?
2022年の状況:
DiscourseのWebhookを使用したZapierインテグレーションがあります:
Discourse Jira Software Server Integration - Quick Connect - Zapier および
https://zapier.com/apps/discourse/integrations/zendesk
また、Zendeskプラグインもあります。
また、Discourse自体にも、トピックをスタッフに直接割り当てる機能、スタッフのささやき、通知リマインダーなど、2017年以降の優れた新機能があり、Jiraなどの外部ツールでチケットを開始する必要なしに、かなり多くのことができます。
