Jump to post is inaccurate in big threads
Users have reported issues with the “Jump to Post” feature in large threads. erlend_sh found that the feature often increments the desired post number by one, and also lacks the blue highlight animation when additional posts need to be loaded. Buzzwig experienced a similar issue with the feature decrementing the URL by one position. After investigation, eviltrout discovered that the issue was due to the feature not respecting hidden gaps and has since fixed it. Additionally, eviltrout confirmed that the feature was not working correctly with the progress widget and has fixed it in master, along with a refactor to clean up the code. The blue highlight animation, which helps guide the user’s eye, has also been reinstated.
It appears when a thread contains a large amount of posts (I haven’t narrowed it down to an exact amount yet) the “post jump” feature has a tendency to increment the desired post number by one.
Also note that there’s no blue highlight animation when additional posts have to be loaded first.
Slightly different behaviour but probably related to the same underlying cause: Following this link in Chrome at 1920x1080 maximised decrements the url by one position as the page loads, and the topic progress bar reads one further position less. (97, 96 and 95 respectively.)
Depends if there are embedded remote linked images, I reckon.
Uploaded images should know dimensions; check upstream and see if any hotlinked remote images are there. Sometimes they’re too big to be converted to local images? Just a guess.
edit: hmm, checking when jumping to #50 and #60 from #1 you might be right. I don’t see any obvious hotlinked images that might be gunking up the works. Worth a look Monday @eviltrout to see if we regressed here.
Jump to posts wasn’t respecting the gaps (hidden). I’ve fixed it and it seems to work well now:
https://github.com/discourse/discourse/commit/1e6dea46ddd12c96a467593d4237b4562876794f
Cheers. One thing I’m still missing though is the blue highlight to help guide my eye. It’s very helpful when you land amongst several smaller posts, and it would also be the consistent thing to do.
Hmm is jump to post not doing a fade? Can you confirm @eviltrout?
I confirmed it wasn’t working when using the progress widget. It’s fixed in master (along with a big refactor to clean it up a lot)
https://github.com/discourse/discourse/commit/78d5d22776cd173bcbd9d5f62ebc1a87fd3a1e23
This topic was automatically closed after 3 days. New replies are no longer allowed.
