Limitare un tag a un gruppo imposta di default su 'visibile solo al gruppo' al primo salvataggio
  • Select Tags are visible to everyone, but only the following groups can use them
  • Select a group
  • Save
Tag is actually saved as Tags are visible only to the following groups
2 Mi Piace
I can reproduce this on my local dev site. What I’m finding is that when the tag group is first created and the ā€œTags are visible to everyone, but only the following groups can use themā€ option is selected, the ā€œTags are visible only to the following groupsā€ will be selected after clicking the Save button:
If I then select the ā€œTags are visible to everyone, but only the following groups can use themā€ option again and save the changes, the correct option is saved:
The issue seems to be related to the position of the group input field in the form.
4 Mi Piace
A fix to address this issue was merged in this morning.
4 Mi Piace
This topic was automatically closed after 5 days. New replies are no longer allowed.
