Let’s say you want to add a link of User’s main profile page on Discourse user profile page and user card, clicking on that link will take user to main (external) website.
The link of main website user profile page will be like:
http://site.com/username
Where username is the Discourse username of that user. (It should be same on both main site and Discourse forum)
Let’s get started!
Add custom CSS
Paste this CSS code in Admin > Customize > CSS/HTML > CSS section:
#user-card .metadata h3 {
float: left;
h3.user-card-public-field {
clear: both;
Add custom JS
Paste this JS code in Admin > Customize > CSS/HTML > </head> section:
<script type="text/discourse-plugin" version="0.8.7">
api.registerConnectorClass('user-profile-primary', 'site-link', {
setupComponent(args, component) {
component.set('siteLink', args.model.get('siteLink'));
api.registerConnectorClass('user-card-metadata', 'site-link', {
component.set('siteLink', args.user.get('siteLink'));
api.modifyClass('model:user', {
siteLink: function() {
const username = this.get('username');
if (username) {
const url = `http://site.com/${username}`;
const link = `<a href=${url} target='_blank'>${url}</a>`;
return Ember.Object.create({ link, name: "User Profile" });
} else {
return null;
}.property('username')
</script>
<script type='text/x-handlebars' data-template-name='/connectors/user-profile-primary/site-link'>
{{#if siteLink}}
<div class="public-user-fields">
<div class="public-user-field">
<span class="user-field-name">{{siteLink.name}}</span>:
<span class="user-field-value">{{{siteLink.link}}}</span>
</div>
</div>
{{/if}}
</script>
<script type='text/x-handlebars' data-template-name='/connectors/user-card-metadata/site-link'>
{{#if siteLink}}
<h3 class="user-card-public-field">
</h3>
{{/if}}
</script>
Update:
with your website user profile link.
Voilà
That’s it, you will now see user Profile link on user profile page:
and user card:
Related: (Retired) Use an ID in a custom user field to link to a user's external profile
「いいね!」 13
pblog
(Mike Sider)
2017 年 1 月 7 日午後 3:48
Works like a charm. Thanks for adding this guide @techAPJ
「いいね!」 3
SidV
2017 年 1 月 9 日午前 11:06
3
@pblog , (or someone) could you please add an screenshot for final result?
「いいね!」 1
techAPJ
(Arpit Jalan)
2017 年 1 月 9 日午前 11:40
4
Okay, added images in OP.
「いいね!」 3
Dear Arpit, does this approach really update userfield siteLink?
We used it “as is” and siteLink in empty under user/preferences siteLink although it is visible over user card
thx
techAPJ
(Arpit Jalan)
2017 年 1 月 25 日午後 5:45
6
You mean user “Web Site”, right?
No, the code in first post does not update user Website field. It just adds a link of main/external user profile on user page and user card.
sunnyt7
(Sunny T)
2017 年 5 月 20 日午前 2:49
7
Sorry for the newbie question, but could someone post example code for if external_id was used as opposed to username?
I have single sign on enabled, and it shows the proper External ID at the bottom of the admin interface of the user account.
daath
(Lars)
2017 年 6 月 22 日午後 3:49
8
Any chance this example could get an update? Apparently it will not work, since api.container.lookupFactory is a private API and will break stuff
sunnyt7:
I asked the same a long time ago. You’d have to write a plugin that exposes external_id - I asked recently if it had become enabled, since they changed a lot of stuff, but haven’t received an answer, so I guess it still requires a plugin…
techAPJ
(Arpit Jalan)
2017 年 6 月 23 日午後 6:12
9
Okay, I updated the code in first post to use api.modifyClass instead of api.container.lookupFactory.
「いいね!」 5
pnoeric
(Eric)
2020 年 4 月 13 日午後 7:48
10
@techAPJ 、このコードは素晴らしいです。少しだけ調整を加えたいのですが、URL の末尾にある external_id を取得する方法をご存知でしょうか(例:const url = 'http://site.com/${external_id}')?ユーザーオブジェクトから external_id を取得するようにコードを変更してみましたが、そのプロパティが未定義であるとエラーが出てしまいます。
Shauny
(Shaun Robinson)
2024 年 2 月 2 日午後 4:51
11
このコードは非推奨です。更新していただけますか?調整してみましたが、うまくいきませんでした。
[管理者通知] プラグインまたはテーマコンポーネントの 1 つ以上が、Discourse 3.2 と互換性がないため更新が必要です。
詳細については、Communiteq ナレッジベース を参照してください。
詳細: [THEME 1 ‘Default’] Function prototype extensions は非推奨になりました。function(){}.property(‘bar’) から computed(‘bar’, function() {}) に移行してください。
david
(David Taylor)
2024 年 2 月 2 日午後 5:00
12
これは別のガイドと非常に似ているようです。あのガイドと同様に、元投稿(OP)で提案されている戦略は極めて時代遅れです。今後最も良い方法は、その機能を git で管理されるテーマコンポーネントに組み込むことで、ユーザーがコードをコピー&ペーストする必要をなくすことです。
うーん、確かにOPで提案されている手法はかなり古いね(2016年に書かれたものだから、そんなものだろうな )。
今では、こういうのはgitリポジトリにパッケージ化して、#customization:theme-componentとして公開し、人が設定からインストールして構成できるようにするのが一般的だよ。
両方のユースケースをカバーする公式の Customization > Theme component を作成できるか検討しており、準備ができ次第、両方のトピックを更新します。
「いいね!」 1
