Login Button /Category Buttons not working
Hi,
I upgraded to the latest version of Discourse tonight. When I click the login button, the button doesn’t appear to function. Also, when clicking Create Category, it appears to try to lightbox but nothing displays in the lightbox. At first I thought this could be custom CSS conflicting with the code, but I disabled any custom CSS. Same issue exists. Any ideas?
Thanks,
Probably an incompatible plugin. Disable all third party plugins and rebuild.
Its a fresh install actually
Sounds like a failed install. I just did a new Digital Ocean install about 3 hours ago and it worked fine.
These are the errors I’m getting before/after rebuilding.
Weird, we can’t reproduce this. You are sure it is a new install with zero changes and zero plugins?
I had added some custom HTML/Nav and had to disable that via rails. Once I did that, back up and running. Thanks
