Looking for a developer to make a moderation add-on plugin
The task is simple! We need below as plugin for our discourse based website.
currently we message users about the reason their post is not accepted. it’s a bit of work, as in a message you need to say hi and bye… This plugin will solve our issue. Also need clipboard shortcuts for repetitive replies within that popup modal.
I can only pay at upwork.com! - No direct payments!
Budget: $50-$100
Did you try Canned Replies?
I also need Need simiar things
@manuel Canned reply is different! I need a post rejection reason popup modal at Moderation page /review while the moderator is rejecting someone’s post/topic!
Yeah, I got that… but you wrote you need clipboard shortcuts for repetitive replies as well?
Also, this sounds like it will not only need a staff interface, but be integrated with user notifications. I’d suspect you will either need to raise your budget, or wait until/whether it becomes a core feature.
If I could recommend an open source alternative:
https://espanso.org/
It’s not built into Discourse, but files are easily shared between users where you can create personal canned/repetitive replies. This might be a good solution to your problem @TheBaby5
