Kleine UI-probleem (404 bij klikken op "meldingen")
Hiya!
I recently stumbled by this UI issue, it’s not major however it is just a little bit annoying.
As a normal user, you see this:
As an admin, you see this:
However as a moderator you still see the “Notifications” tab, however, when you click on it, it leads you to a 404.
My idea:
I personally think it would be more effective to remove the “Notification” tab for moderators, or to make it work, either way: I don’t mind!
This is actually a minor bug, we should not be rendering a link to moderators that gives them a 404, we will get it sorted over the next month.
The notifications tab is now removed for moderator users.
