Upgrade link shown to moderators on dashboard
Not a bug as such, but the link for the upgrade process is shown on the new dashboard to moderators:
Clicking the link doesn’t work (shows the “You’re not permitted” note).
I wouldn’t call this a bug, because per the definition in the bug category, normal operation is not prevented. The moderator will get a 404 page which is no different than navigating there manually.
That said we should still address the issue by suppressing this text for moderators @j.jaffeux
This will fix it:
I also noted to rework this when we remove the old dashboard, it’s currently using table formatting, which is working OK in the new dashboard but not ideal.
