More formatting bugs with font size refactor
Hello! A few days ago, me and @JonnyGamer submitted a bug report regarding “topic nuking”. Discourse fixed this really fast, but now, there are a few more bugs that @JonnyGamer and some others has found at forum.gethopscotch.com.
Firstly, I have no idea whether these bugs are because of the configuration as I don’t are an admin, and if this isn’t a general software bug, you could just close the topic, I don’t mind.
The first bug can happen if you repeat the code (any letter)<big><small><sub>. This will cause posts to break like in this example topic:
https://forum.gethopscotch.com/t/test-topic-nukes-and-spamlikes-watch-this-jonny-gamer/40314/15?u=william04gamera
The second bug kind of breaks the tag system. I’ll quote @JonnyGamer’s “bug report”:
@JonnyGamer:
When writing tags for your topic, write one of them as: ﷽﷽﷽﷽﷽﷽﷽﷽﷽﷽﷽﷽﷽﷽﷽﷽﷽﷽﷽﷽
﷽ is the widest unicode character that fits into the forum. And since you are only allowed to have a tag be at max 20 characters, “﷽” is the widest for this form.
He also included a screenshot:
Once again, all credit goes to @JonnyGamer and anyone else involved in finding these bugs.
These are the bugs I consider as the most important ones, but there are a few more reported here:
https://forum.gethopscotch.com/t/official-guide-to-breaking-the-forum-keep-in-lounge-because-yall-regulars-are-trustworthy/40312?u=william04gamera
Some bugs that I didn’t write about here that are in the topic above are due to configuration bugs in the forum itself, like the fact that words starting with f and ending with k are getting censored.
To reach the topic above, you have to be Regular on The Hopscotch Forum. I think that @techAPJ already have a leader account there, so he/she might be able to see and get more information about those bugs.
I hope that you at Discourse can fix this!
2 лайка
Awesome topic! Thanks!
Yeah, we are learning of new bugs/glitches each day! Here is something else that I found interesting:
K​:ok_hand: K​:ok_hand: K​:ok_hand: K​:ok_hand: K​:ok_hand: K​:ok_hand: K​:ok_hand: K​:ok_hand: K​:ok_hand: K​:ok_hand: K​:ok_hand: K​:ok_hand:
2 лайка
Quoting gets really wonky, too :/
2 лайка
Last bug of all with this interesting idea:
When you add an <s> before the text, you get these weird bars in between each slashed word:
2 лайка
Thanks for reporting these, the tag name exploit was definitely the worst one because it broke the page layout for everyone. I also fixed some of the issues with the big/small/sup/sub tags, so once Discourse is updated those won’t cause any more problems.
7 лайков
This one is not a bug. <s> is intended to create a strikethrough - a line through the words. It’s typically used to clearly show that something has been changed, like a tyop typo.
2 лайка
Okay - that’s great! Thank you for fixing those bugs!
1 лайк
Ok, thank you!
You might have seen this post after they fixed the bug. It originally looked like this:
There are weird bars in between of each slashed “k :ok_hand:”
2 лайка
That’s not too weird: there’s a space between each “k :ok_hand:”, and the <s> creates a strikethrough, so the bar is a strikethrough on a space. And since the space is outside of the <sub> tags, the space is higher than the text that comes after it.
3 лайка
Ah, ok, that makes sense (Still kid of weirded me out when I saw it first :joy:)
2 лайка
Found another weird bug:
  • ksksksksksksksk
  • :black_medium_square::black_medium_square::black_medium_square::black_medium_square::black_medium_square:
  • jajajajkajak
Hmmm, on the discourse, it is a-ok
2 лайка
Testing:
2 лайка
Even weirder:
3 лайка
By the way: I’ve noticed that someone changed the tag style inside text fields. I really don’t like it. The old style has more white space on top and bottom. On the right and left side, I’m missing a little bit of grey space. It’s very irritating if tags are displayed on different ways :wink:
Sometimes I wish, there are more settings / style options for tags :wink:
Update: Here is a second issue at the category page with the bullet point style:
4 лайка
Apparently this regression only happened recently. I upgrade to latest version and it starts showing up.
4 лайка
Right, this is actually unrelated to font changes. It turns out that tags had no max-width restrictions, which allowed someone to break the layout of pages by making tags with characters like: ﷽. Now tags that are too long are truncated with CSS, and adding the ability to truncate caused some alignment changes.
@terraboss @schungx I’ll take a look at the bullet/box tag styles now and make sure those alignment issues are fixed.
8 лайков
I found another bug with font sizes <sub>, but I ask you not to fix it because it’s really cool. With this glitch, you are able to overlap characters to create some interesting designs:
https://forum.gethopscotch.com/t/create-your-own-emoticons-forum-glitch/40357
Now you can make little guys:
O
(OO)
I personally think it’s really cool, but it also allows weird stuff like this:
Hello hello hello
Test test test test
Thanks!
6 лайков
@awesomerobot is there anything else we need to do here? or should we close?
1 лайк
This is all set. The remaining items are weird things to do that really only break your own text.
4 лайка
