“Move to existing topic” search silently fails while site search still works
The issue involves the “Move to existing topic” modal in Discourse failing to refine search results as users type, despite network requests returning 200 status codes and correct parameters. Ethsim2 notes that the /search/query endpoint works, but the topic list remains static. Initial suspicion was that pg_trgm was missing in Postgres, but it is confirmed to be enabled. The issue may stem from a stale or inconsistent search index, prompting a plan to run rake search:reindex. The problem is isolated to the topic chooser and not full site search, which functions normally. Moin adds that similar issues have been reported, and the lack of feedback makes it confusing for admins. Ethsim2 later observes that the issue resolved temporarily, suggesting a possible client-side state or caching issue, and plans to compare JSON responses and test Safe Mode to determine if it’s a known edge case or regression.
Hi,
I’m seeing an issue with the “Move to existing topic” modal (this previously worked on my site, so appears to be a regression):
  • Typing in Search for a Topic does not refine results
  • Network requests return 200 with correct parameters
  • No JS errors in the browser console
  • Whole-site /search works as expected
  • The issue has persisted across rebuilds
Example request being made:
/search/query?term=Eve Park&type_filter=topic&search_for_id=true&restrict_to_archetype=regular
The chooser list appears to remain a static set of topics and does not change as the term changes.
After client-side debugging, I initially suspected this might be caused by pg_trgm not being enabled in Postgres, but wanted to confirm this before proceeding.
I ran the following commands:
./launcher enter app
rails c
ActiveRecord::Base.connection.execute(
  "SELECT extname FROM pg_extension WHERE extname = 'pg_trgm';"
).to_a
This diagnosis would be valid if the command returned:
However, instead it returned:
[{"extname"=>"pg_trgm"}]
So pg_trgm is enabled, and this does not appear to be the root cause.
I therefore intend to run the following command:
rake search:reindex
This may be relevant because a particular category of my forum has a very large number of topics.
What’s confusing is that:
  • Discourse otherwise continues to function normally
  • Full /search works as expected
  • The topic-move autocomplete silently degrades instead of warning
As part of debugging, I also enabled the search prefer recent posts setting and reloaded the browser. This had no effect on the behaviour - the “Move to existing topic” search still does not refine results as I type.
Since that setting only affects full /search ranking and not the topic chooser endpoint, this seems consistent with the issue being specific to /search/query rather than general search performance.
Before running rake search:reindex, I wanted to sanity-check the reasoning:
The topic-move chooser uses /search/query with search_for_id=true, which relies more directly on indexed lookups than the full /search endpoint. A partially stale or inconsistent search index could therefore affect the chooser while full search still appears to work.
Given that:
  • the endpoint is being called,
  • responses return 200,
  • pg_trgm is enabled,
  • and toggling search prefer recent posts has no effect,
A full rake search:reindex seems like the next logical step to rule out index inconsistency. Separately, the lack of any warning or feedback makes this particularly confusing from an admin UX perspective.
That search has never been reliable in my experience. For example, there is also this report: Topic can't be found when searching for a topic (verbatim) when moving a post.
I usually enter the topic ID and use the site’s search to find that.
Thanks - that’s helpful context, and the linked report looks very similar.
What’s odd in my case is that it did behave “non-responsive” when I wrote the OP: /search/query was being called with term=Eve Park etc. (200 responses), but the chooser list stayed static and did not refine at all.
Since then, I can now reproduce the intended “responsive search” behaviour (as shown in my Safe Mode recording) side-by-side with another browser window.
I haven’t changed anything on the server beyond what I described in the OP, so my current suspicion is that I initially hit either:
  • a client-side state issue (cached assets / hard refresh difference / theme component interaction), or
  • a query edge case where certain terms don’t return as expected (verbatim / punctuation / stop words / ordering), similar to the “verbatim move search can’t find topic” report you linked.
Next I’m going to compare the actual JSON response from /search/query between the “non-responsive” case and the “responsive” case (same term), and I’ll also run Safe Mode again with/without themes to see if it correlates.
If anyone knows the exact matching rules used by the move-topic chooser (vs full /search) or where it differs, that would be super helpful - I’m trying to pin down whether this is a known limitation/edge case or a regression.
