Moving a topic to another category doesn't propagate
Steps to repro:
  1. User A create a Topic on Category I
  2. User B enters topic
  3. User B moves Topic to Category II
  4. User A still on topic, but it didn’t updates the category
Aggravating:
  1. User A, still on topic, makes a small edit on the text. Topic gets moved back do Category I.
I may be wrong, but this sounds similar to the issue reported here and apparently fixed.
Sort of. But ours specifically dealt with a restricted category, @falco’s doesn’t. You can use two public categories and produce the same results.
It is a “transaction” type of thing.
Similar to when a member makes a poorly formatted post, the tries to edit it.
If at the same time a Mod fixes it before the member finishes the Mod fix will be replaced with the member fix when they Save.
I think most times the chances of more than one working on a post / topic at the same time are rare. Though the problem has come up before, wiki edits in particular.
I know databases can lock transactions, but I don’t know how it could be dealt with here.
I have seen it suggested to prevent further topic replies if another is in the process of replying, which I think is a poor idea.
But it might be nice to have on a per post level.
I’m thinking on a rather simpler approach here:
If the user hasn’t clicked on the edit button yet, the topic state (title, category) should update automatically.
Hi
I tried to repro and that is what I found, I could not repro the ‘aggravating’ from OP.
  • userA and userB have the topic open in the editor, topic category is I.
  • userA changes topic to category II and posts something
  • userB receives the reply immediately, but for him topic is still in category I, i.e. the post count and content refresh but the category and title do not.
  • if userB replies (for him the post is still category I) this does NOT put the topic back to category I. If userB leaves the editor he will see the new category for the topic in the topic list.
I think the category and title change commit button should really trigger the same type of refresh event for category and title that is triggered by the reply button if that makes sense.
I’m having a look at this.
We’ll now publish the changes to TopicView when the topic changes.
https://github.com/discourse/discourse/pull/4139
A few improvements I can think of but will be much trickier to implement:
  1. Perhaps we should reload the topic object globally when the topic changes?
  2. Publish a notice in the composer when user is editing a topic that has been changed.
I’ve tried your changes on my instance @tgxworld and it works perfectly, title update and category update are broadcasted now! Great work!
I just tested this multiple times on meta from all the places and seems to work fine
