תגיות פורום מושתקות לא נראות בדף הבית כשצופים או עוקבים
סיכום מבוסס בינה מלאכותית
A user, polkaparrot, has reported an issue where threads with muted tags do not appear on the main/latest page, even when set as watching/tracking. Canapin has reproduced the issue and believes it to be inconsistent with how muted categories work. When a category is muted and a topic within that category is tracked or watched, it still appears on the Latest page. Canapin suggests this is either a missing feature or a bug and has moved the topic to the bug category for further investigation.
I have a certain tag muted under a category, because there are a lot of weekly threads genereated that are irrelevant to me. I still have few threads there I want to follow, though. However, even if I have those threads as watching/tracking, they don’t show up on my main/latest page.
I don’t think that’s how it’s supposed to work, as I believe this is a pretty common use-case? At least muted categories show up when you track/set them as watched, so this feels a bit inconsistent.
Any thoughts? Is this a bug?
5 לייקים
Hi, polka :parrot: !
It seems related to Muted categories should not hide Tracked/Watched topics, where a change was made:
Other changes have been made after, so the code isn’t the same anymore, but it fixed the similar issue for categories.
I can repro the issue you describe:
  1. Mute a tag
  2. Track or watch a topic having this tag
  3. The topic doesn’t appear in Latest. When a new message is created, it only appears in the New tab, but not on Latest.
Right: posting on the watched topic having a muted tag.
Left: the notification only appears on New, but the topic never appears in Latest.
I feel the behavior should be the same as with the categories: if I mute a category and then track or watch a topic from this category, it always appears on Latest.
It seems like a missing feature, but feels more like a bug because the behavior is inconsistent with how categories work in this regard, so I’ve moved your topic in Contribute > Bug.
5 לייקים
