my website is not running
I have error (HTTP ERROR 500) i think because my version: 2.1.0.beta4
please tell my how i can upgrade my website to last version
note: I used AWS
and please I want a clear explanation because I am a beginner
note: I used AWS
Did You install it Yourself or did someone install it to You?
In case You installed Yourself, the easiest way to upgrade is to SSH into Your server that is hosting discourse and run the following set of commands:
cd /var/discourse
git pull
./launcher rebuild app
Otherwise, contact the person who did the installation part as they may be able to help You.
I installed with someone togather before 1 year ago but now I didn’t found him
when I follow your step
i get this errorr
error: cannot open .git/FETCH_HEAD: Permission denied
Are you performing this as root?
oh I forget this step
I do it now but this problem appeared to me
remote: Enumerating objects: 285, done.
remote: Counting objects: 100% (285/285), done.
remote: Compressing objects: 100% (11/11), done.
fatal: write error: No space left on device
fatal: index-pack failed
I exceeded the permissible limit. Do you know possible way to expand?
df -h
Filesystem Size Used Avail Use% Mounted on
/...... 20G 20G 0 100% /
You should be able to do that. You would need to stop the instance first, amend the storage and then reboot.
That’s a little off topic for Discourse Meta though and you should refer to Amazon’s EC2 documentation.
If you need more help I’d recommend posting for a freelancer experienced with EC2 in Marketplace
I followed this lesson and applied until I got to step number (7)
I didn’t understand it.
can you explain the last 3 steps please
