Hello mates,
hope you guys have a solution for my problem.
Just installed discourse on a Ubuntu 16.04 System with Plesk on it, using this guide and the official setup guide.
very straightforward guide. I made every step as described, but I will point them here again fast:
- created subdomain in plesk panel
2. edited discourse-setup to use port 8060 & 9443 - edited discourse-setup to: check_port “8060” & check_port “9443”
- performed install like described in github
- edited app.yml to use described ports 8060:80 & 9443:443
- rebuild app
- for the subdomain edited nginx proxy rules, btw. added the rule for 8060:80
Error in brwoser is 502 Bad Gateway, nginx and in Plesk error logs from the subdomain:
2938#0: *341 recv() failed (104: Connection reset by peer) while reading response header from upstream
I am out of mind now, I don´t know what to do…
Cheers, Daniel
