Hi all,
I just connected discourse and wordpress via wp-dicourse, for blog post, the plugin working fine, but for woocommerce product page, no comments function display on product page.
I need some help for fixing it, Thx.
Hi all,
On the WP Discourse Publishing Settings tab, scroll to the bottom of the page to the ‘Post Types to Publish’ setting. You should see an option there for ‘product.’ Select ‘product’ and make sure that ‘post’ is still selected as well. After saving the options, you should be able to display comments for products.
It is working now, thx.
