לשונית ההתראות ממשיכה להיטען ב-Edge עבור אנדרואיד
Members on our forums who use Edge for Android reported that notification tab keeps loading without showing notifications.
I was able to repo this using Edge on Android phone:
Any ideas why this is happening?
2 לייקים
Also happening in Free Adblocker Browser for Android.
לייק 1
Can you reproduce this on meta?
לייק 1
Yes, it’s the same issue:
2 לייקים
Are you able to tell me what version of edge for Android you have please ?
לייק 1
I installed it couple of days ago to check out the issue.
לייק 1
Two of our users report the same problem on Android 10 and 11… Edge 46.06.4.5160.
לייק 1
This is what I was suspecting, edge has been for long time way behind chromium updates, it should now be possible to update it too a much newer version.
לייק 1
I tried Edge Beta for Android and everything works fine. Hopefully they will update Edge app soon.
Thank you all for the feedback!
3 לייקים
Cool, we will still work on having something better than a white screen, but if you can update yes it’s better :wink:
3 לייקים
I think we can detect the EdgA UA string and make it use the HTML only version. The new version uses the Edg string.
2 לייקים
This was a browser incompatibility in our JavaScript code, should be fixed by:
https://github.com/discourse/discourse/commit/814aa64a5d089d25f893c334714f2feac8d2a4ae
9 לייקים
This topic was automatically closed after 2 days. New replies are no longer allowed.
