Notifications when a topic is recategorized
This discussion addresses a bug where users watching a category do not receive notifications when a topic is recategorized into that category. simon first reported the issue, noting that topics moved from one category (e.g., ‘extras’) to a watched category (e.g., ‘wordpress’) fail to trigger notifications. sam confirmed the behavior is intentional to avoid complex ‘unwatch’ logic, but simon proposed a workaround: manually replying after recategorization to trigger notifications. However, tophee noted this doesn’t work for ‘watching first post’ preferences. SquareTheBase emphasized the impact on tag-based watching, which is common in triage-heavy support forums. tgxworld initially struggled to reproduce the issue but later confirmed the bug and fixed it in a commit. simon verified the fix on try.discourse.org: users watching the target category now receive notifications upon recategorization. The fix ensures notifications are sent when topics are moved into watched categories, improving support workflows where staff frequently reassign topics.
On this forum I am watching the support/wordpress category. A few times, I’ve noticed topics in that category for which I haven’t received notifications. Here’s an example of one: WP + Discourse SSO Continuity Issue
Looking at the edit history of that topic, it has been recategorized from extras to wordpress. Possibly this is a regression from https://meta.discourse.org/t/category-watch-preferences-not-honored-on-recategorization/19441/7?u=simon_cossar
3 إعجابات
What do you think @sam? Relevant only to old prefs?
yeah we do not add a watch on recategorization, its a bit tricky cause we would have to “unwatch” strategically when you remove a category.
This could cause problems for a forum that is being used for customer support.
A non-technical solution is for the person who recategorizes the topic to add a reply to the topic that explains that they have moved it to the appropriate category. People watching the category will then get a notification. (I’ve only tested this on my local setup.)
إعجاب واحد (1)
Though this will only work for “watching”, not for “watching first post” (which is one of the big plusses of a discourse forum).
But it might work if you use the topic timer to republish into a new category. Or so I thought. Apparently it only works under certain conditions? Or does a scheduled publication never trigger notifications because the post has technically already been published?
إعجاب واحد (1)
Anyway to at least implement Watching First Post so those users get notified when the topic is new to them? It wouldn’t seem to be affected by the “unwatch” trickiness.
Most of our uses never add tags on topic creation and it’s a triage effort by staff which means all users that are watching tags will never get notified. :cry:
إعجابَين (2)
This is an edge condition we should patch @tgxworld
إعجابَين (2)
@simon Are you stil able to reproduce this problem? I tried to reproduce this locally but I’m getting the correct notifications even after a topic is re-categorized.
إعجابَين (2)
Yes, I’ve just tested it on a hosted instance. I have three users, user_a, user_b, and user_c. I have set user_a to watch the ‘scratch’ category.
When user_b creates a topic in the ‘scratch’ category, user_a gets a notification about it when they login to the forum. This works as expected.
When user_b creates an uncategorized topic and then user_c recategorizes the topic to ‘scratch’, user_a does not get a notification when they login.
4 إعجابات
What I tested is that notifications are correctly delivered when a new post is created in the topic that has been re-categorized. Do you mean we should resend the notification when a topic gets re-categorized?
إعجابَين (2)
Yes. The case where this comes up for me is that I’m watching the Support > WordPress category. WordPress support topics are sometimes created in the wrong category and then moved by a staff member. When that happens, it would be good to get a notification.
A notification would probably be sent in this case if recategorizing a topic created a moderator post.
5 إعجابات
I think this is the same issue discussed here:
I wonder if this also applies to publishing topics created using the shared drafts feature…
5 إعجابات
@simon I fixed it in
https://github.com/discourse/discourse/commit/ee1eb1a5bd834ed49e7efe2ee58bb567556a8c7c
8 إعجابات
OK, tomorrow can you verify this is working as you expect here on meta @simon?
I just tested it on try.discourse.org and it worked as expected. When a topic is recategorized, users who are watching the recategorized category get a notification.
6 إعجابات
