LeoMcA reported not receiving notifications for announcements despite having #feature:announcements set to Watching. david suggested that the issue might be related to posts being drafted as PMs or shared drafts, which don’t send notifications.
After testing, david found that publishing a shared draft in a watched category triggers a notification, but making a PM public and recategorizing it does not. jomaxro confirmed that the last three release notes were created using shared drafts, which might have caused the issue.
A fix was proposed by sam, and tgxworld applied a change that should fix the issue. However, LeoMcA reported that the problem persisted.
codinghorror suggested that the issue might be related to posting as a shared draft, and david eventually identified the regression and submitted a PR to fix it. The fix is now merged, and future #feature:announcements should trigger notifications correctly, as confirmed by david.
I have #feature:announcements set to Watching, but for the past 3 or so sets of release notes (like this one) I haven’t received a notification for it, and have only found it in my New list.
Once I open the topic, it says that it is set to Watching, despite my not receiving a notification for it.
@david very likely has the right idea. The last 3 or so release notes were created using the shared drafts feature. Previous notes were drafted elsewhere and posted “normally”. It looks like @tgxworld’s recent change likely fixed watching #feature:announcements, but we should probably fix the other 2 issues.
@tgxworld I would like you to fix this, this week if you have some time
A minimal fix here is that if a topic with 1 post is recategorized to a “watching” category notifications should go out.
It is a bit tricky here cause, what happens when you move something to #feature:announcements and then move it out of #feature:announcements ? We need to remove the watching status from all the people to be “correct”
Unfortunately it doesn’t look like this is completely fixed, as it happened again for me with: Discourse 2.1.0 beta 2 Release Notes (I got no notification, only appeared in New, appeared as Watching once I opened it)
It looks like most of the cases described above regressed 2 months ago, but this wasn’t picked up in the tests (because Sidekiq jobs don’t run normally in a test environment). Here’s a PR to fix:
