Hi All,
I hope you are well,
i usually have banners displaying on top and bottom of articles but since i did the last update, i know have :“[object Object]”
Do you guys know why ?
What was displaying the banners there?
That usually means that an object with several fields is being referred to rather than one of the fields.
What’s changed lately?
Hi @pfaffman,
I didn’t touch anything,
I just did a ./launcher rebuild app
What was generating the banners? A theme component?
Do you see anything in the javascript console?
You didn’t do nothing. You upgraded? Lots of stuff had changed lately.
@pfaffman if i remember well, i injected the banner display widget in the house banner plugin.
so now it just display this.
I only rebuild, nothing else special.
Then that’s what to change. The widget stuff is deprecated. You’ll need to change your you’re doing that.
It is now working back. I don’t know why… but why not ![]()
