Hello. After update and reload server with docker i see this header on any page and JS not work fine. Trey to restore from backup, but it’s nave not effect. Maybe there is any cache or else?
You should rebuild your container.
Rebuild two time, not help.
Do you have any plugins installed?
Try removing babble and vk.com, they might not work with the latest version.
Okay, i need to modify yml and rebuild container?
Vk should be fine but babble is a bit broken for the next few days
Yeah, just comment the lines in the yml file and rebuild your container.
1 „Gefällt mir“
