I just exported data from Vanilla 2.1.18p2 (latest) using the Vanilla 2 format (should I use Vanilla 1?) and tried to import here as the discourse account:
discourse@ubuntu-app:/var/www/discourse$ RAILS_ENV=production ruby script/import_scripts/vanilla.rb /shared/backups/export_vanilla_2015-01-27_113009.txt.gz
/var/www/discourse/script/import_scripts/base.rb:14:in `<top (required)>': undefined method `require_dependency' for main:Object (NoMethodError)
from /usr/local/lib/ruby/site_ruby/2.0.0/rubygems/core_ext/kernel_require.rb:54:in `require'
from script/import_scripts/vanilla.rb:1:in `<main>'
I tried all other command suggestions from this page, normally thor can’t be found, etc. this is the only command that works, but I get this error.
Before I tried to import, I created one Administrator and two Moderator accounts in Discourse, thinking that’s required. On the Vanilla site I have several Administrators and several Moderators, all with different email accounts to existing on Discourse.
importing users...
script/import_scripts/vanilla.rb:82:in `import_users': undefined method `[]' for nil:NilClass (NoMethodError)
from script/import_scripts/vanilla.rb:19:in `execute'
from /var/www/discourse/script/import_scripts/base.rb:77:in `perform'
from script/import_scripts/vanilla.rb:255:in `<main>'
Previosly i read that this problem is based on roles. But can’t find how to solve it.
Check around line 82. If your Super Moderator and Admin roles aren’t named as such (or it can’t find them), just hardcode the ID of each respective role.
