[Paid] Upgrade to latest Discourse build, permanently delete posts, and more
Project Requirements and Budget
JoelZaslofsky is seeking a developer to perform several tasks on their Discourse forum, including:
  • Deleting or merging duplicate tags in the database
  • Uninstalling the Follow plugin
  • Permanently deleting posts with “deleted” IDs to save server space
  • Updating the test server to the latest Discourse build
  • Updating the production server to the same build after testing
The project must be completed within the next 45 days, and the budget is $150.00 USD.
itsbhanusharma initially expressed interest in taking on the project but later declined due to other priorities.
What would you like done?
  1. Delete or merge the duplicate tags in the database. According to a Data Explorer query, I have 9 of them. The context behind the issue and the rails solution to it is described in this Discourse Meta forum thread.
  2. Uninstall the Follow plugin.
  3. Permanently delete anything from the database where the post ID or reply ID is “deleted”. This and this Discourse Meta forum thread are useful starting points. The main reason for permanently deleting these items is to save space on the server, but also so I don’t have to account for them when I run various Data Explorer queries.
  4. Update our test server to the latest Discourse build. That would include saving the Discourse package somewhere (e.g., GitHub) where you could use the exact same package for a production server update after I had time to test.
  5. Update our production server to the same Discourse build as was tested on our test server.
Both servers – production and test – are on my business partner’s Vultr account. I have all the SSH and other credentials you’d need to do the work.
When do you need it done?
In the next 45 days.
What is your budget?
My budget is $150.00 USD.
I’ll be happy to take this on. Drop me an email to bhanu@orng.co and we can discuss.
EDIT: I’m sorry @JoelZaslofsky, Since I haven’t heard back from you, I’m afraid that I’ll have to pass this up to someone else willing to take this on. I have some other priorities set for the coming week(s).
