For a week or so, I’ve had a single notification (green) count badge shown in my DiscourseHub app. Similarly, an iOS update count badge of 1 is shown on my homescreen against the app
In the forum itself I have no notifications, and no unread messages.
This is driving my OCD and notification-dopamine cycles really crazy. Any suggestions on how I can find the root cause?
I’ve tried reinstalling the app. That didn’t help.
Also looked at the https://forum.caption.me/notifications.json endpoint but all the notifications there were "read":true
2 לייקים
Firepup650
(Firepup Sixfifty)
5 באוקטובר, 2023, 10:49am
Try getting another notification there, then using Dismiss All . That might kill your phantom notification
3 לייקים
Great idea @Firepup650 . I tried this and initially it didn’t seem to work. Then I swiped to delete my forum from DiscourseHub and re-added it. At that point there were zero notifications. Problem solved! Many thanks.
3 לייקים
Jagster
(Jakke Flemming)
5 באוקטובר, 2023, 11:24am
4
I have same. Came after I moved messages between channels. This is an issue that bothers DiscourseHub every now and then. It was away quite a time but I reckon it came back after latest update of the app.
Sure, deleting an instance is one solution. I hate it because it breaks order of forums and I’m working on muscle memory
It will go away after some time, on my forum it takes one week if I’m remembering right my settings.
3 לייקים
It is possible to re-order the forum list by long-pressing and dragging
3 לייקים
Oh no! The phantom notification is back
Seemed to correspond with a timed bookmark reminder - I wonder if the bug relates to that feature?
לייק 1
jeffbyrnes
(Jeff Byrnes)
7 באוקטובר, 2023, 3:03pm
7
I’ve got the same experience, it seems to be linked to private messages not being seen as read.
2 לייקים
I had the same problem. It didn’t seem to be clearing after a week so I’ve just removed the forum from DiscourseHub and added it back again. Notification cleared.
3 לייקים
spdegabrielle
(Stephen De Gabrielle)
16 באוקטובר, 2023, 11:07am
9
The mobile app shows an outstanding notification, both in-app as a number 1 in a green losenge to the right of the server name, and a corresponding red notification on the app icon in iOS
I’ve used the desktop ui via chrome to verify I have no outstanding notifications.
This seems like it only started in the last few days or weeks.
Has anyone else experienced this?
PS removed and reinstalled in case it was a data problem
לייק 1
Firepup650
(Firepup Sixfifty)
10
Try removing the forum from the app and then re-adding it.
Also, this topic is about the same issue:
[IMG_4810]
Also looked at the https://forum.caption.me/notifications.js…
לייק 1
spdegabrielle
16 באוקטובר, 2023, 1:40pm
11
Ahh thank you.
I think I’ve been able to reproduce:
Removing and re-adding the server removed the green losenge, but another (private) chat message reinstated it, but reading the related message did not clear the indicator.
S.
לייק 1
spdegabrielle
16 באוקטובר, 2023, 1:41pm
12
לייק 1
See there’s a green moderation notification badge
Open forum to find out it’s already been taken care of by another moderator
Notification badge doesn’t go away
The only way I can get this to disappear is to completely remove the forum and re-add it to the iOS app.
So it seems like an app caching issue?
iOS App: 1.8.11
Discourse forum: 3.1.2 (ef3f415439)
spdegabrielle
19 באוקטובר, 2023, 6:41pm
14
So I’ve successfully reproduce the problem, but how do I log a bug report?
Let’s combine these two topics and slip them into the Contribute > Bug category to see if we can get someone to take a closer look.
2 לייקים
Is this using DiscourseHub?
If so, I think we have another couple of reports on similar that I can merge this one into as well:
[IMG_4810]
I think Red is Review Queue notifications, and green is normal notifications, if that’s relevant too.
pmusaraj
(Penar Musaraj)
19 באוקטובר, 2023, 7:02pm
18
Thanks for the detailed report!
Do you, by any chance, remember where you read the chat message? Was it in the DiscourseHub app?
Yes, the iOS app DiscourseHub.
edit: got my colours mixed up.
With the red one you have to find the unread item which is like finding a needle in a haystack. But it’s possible.
With the green one removing and re-adding the forum is enough to clear it.
Also see this 3-year-old issue of mine about disappearing badges. iOS app: viewing first forum erases notifications of second - #26 by gingerbeardman
I think there’s something really wrong with the badge system in the app.
לייק 1
I’ve merged it in. I think I may have pushed the ‘merge and keep chronology’ to the limits with this topic though, but I think it still makes sense.
2 לייקים
