When I click ‘Pin globally’, nothing happens. Topic does not marked as pin at all.
Also, If I click ‘Pin’, option ‘Pin globally’ disappears from options list, is it as intended?
Thanks.
Thanks.
Which version are you running?
Latest: updated about hour ago.
This:
[Error] Error: Nothing handled the action 'togglePinnedGlobally'. If you did handle the action, this error can be caused by returning true from an action handler in a controller, causing the action to bubble.
run (undefined, line 23524)
run
handleRegisteredAction
(anonymous function)
dispatch
handle
Ok, I’ve disabled 2 plugins (curated home and locale override), rebuilt app and everything seems work fine now.
