We publish category now with the “new information” I am not against adding publishing of tags as well in core.
The tricky thing though is that this adds an extra join each time we publish info. Additionally, when we generate the initial cache we do not include tags, adding them will be expensive.
I’ve just seen that I can get the unseen topic ids from the topicTrackingState.state object (as you mentioned, I can see the category in there, but not the tags). So here is a better plan:
Observe the topicTrackingState.messageCount property.
Each time there’s a change, use the API to load the unseen topics and get their tags
Tell me if I’m wrong, but a consequence of this tag limitation is that, when you’re on a tag page (example here), any new topic with that tag won’t trigger the “1 new or updated topic. Click to show” message.
