I am wondering if there is a plugin to remove the sidebar and make the forum categories the homepage
not sure what you mean. the navigation menu (side bar) isn’t a page on its own and collapses, regardless of what page you’re on.
can you explain in more detail what it is you are wanting? i think you might have some terms mixed up or aren’t aware off some existing functionality and settings.
the hamburger icon (top left beside logo) collapses and expands the navigation sidebar menu.
Sorry for the confusion.
As you can see with the WeMod community they’re also using Discourse, there community homepage shows the forums right away and they also don’t have the collapsable sidebar. The have the sidebar features in the top right corner.
go to admin - settings navigation menu
and you can change sidebar to header drop down.
note that the “legacy” setting is being phased out at some point.
Thank you so much! How can I change the landing page so its not recent topics and just the categories?
admin-settings desktop category page style
keep in mind users can set their homepage in their preferences under interface
you’re very welcome. i’m glad i could help.
the topic will close on it’s own or if a community moderator decides to close it. often old topics can be helpful. you can mark a post solution as solved though
