Porta 443 bloqueada no Discourse Digital Ocean com um clique
how to fix it ? im using digitalocean one click app
1 curtida
It’s probably because of Cloudflare incompatibility with the installer. Maybe try disable Cloudflare proxying (orange cloud) for your A records temporarily while installing or just manually edit the app.yml and rebuild (that’s what I do).
2 curtidas
how to edit app.yml ?
check it its ok now ?
1 curtida
cd /var/discourse
nano containers/app.yml
Don’t forget to add this in the templates section at the top of your app.yml:
- "templates/cloudflare.template.yml"
Add the necessary info, like hostname and smtp credentials.
Save and exit, then run:
./launcher rebuild app
1 curtida
Yeah that looks good, if you try the installer now with that disabled hopefully it will work. If it succeeds, you will still want to add the cloudflare template to the app.yml and rebuild.
1 curtida
how to add hostname and smtp in it
1 curtida
You have to scroll further down the file to see those fields. Did the installer fail even with Cloudflare proxying disabled?
1 curtida
here can i use gmail ? b
coz other mail server was paid any free mail server /
1 curtida
I recommend AWS SES, it’s the most cost effective top tier service I know of. It’s not free though, but it’s cheap and usage based with no minimums.
Not sure for using a free Gmail, I haven’t tried. You might want to search around the forums for that.
1 curtida
aws ses starting price free for 12 months
I think that is only for if you are hosting Discourse with them on an EC2 instance unless I’m mistaken.
2 curtidas
okay i’ll try sendgrid
1 curtida
Mail gun is a great SMTP provider, you just need to verify with a credit/ debit card, but it won’t charge you anything.
