Contenu du message (partiellement) perdu lorsque « Enregistrer la réponse » échoue en raison de problèmes de connectivité
When “Save Reply” happens while the internet connection is temporarily down (as just happened to me several times in this train), the content of the post are partially lost.
Steps to reproduce:
  • Start writing a reply.
  • While writing, cap your internet connection.
  • Hit “Save Reply”.
  • Some time later, restore your internet connection.
Expected behavior:
At some point, the “Saving…” process should give up and bring me back to the editor (or at least show a “Cancel” button that does this), so that I can try again to submit my response.
Actual behavior:
The “Saving…” bar at the bottom just sticks around with a spinning circle endlessly. The “expand” button it shows does nothing when clicked. The only thing I can do is to hit F5, which will restore some prior version of the post (not sure if from a local or a server-side cache) – but my last few sentences are lost.
I just had this happen 4 times in a row. At least the last two times I remembered to manually copy the post content before submitting, but that really should not be necessary.
Where are you seeing a “Save Reply” button? I am not aware of any such button in Discourse.
Drafts are saved automatically at regular intervals, provided the content has changed and there is enough content to save, beyond the minimum character limits.
Sorry, it’s called just “Reply”.
I just ran into this again, losing entirely the edits I made to a post because my connection was down when I hit “Save Edit”. Once the connection was back, when I reloaded the page, my edits were just gone. Seemed like when it tried to auto-save on the server there already was no connectivity, and it did not even try to auto-save locally?
Can you describe the time span of this edit in seconds, and how many characters you edited, roughly?
As I mentioned earlier, drafts are automatically saved at regular intervals but it requires a certain duration of editing.
The edit was about adding 2 sentences. Not sure how long that took me, something between 30s and a minute?
So are you saying drafts should be saved locally, in principle? Would it then be possible to trigger another local save just when I press “Save Edit”, to make sure the latest version of saved before irrevocably disabling the editor?
C’est toujours un problème dans la dernière version de Discourse (enfin, quoi que https://internals.rust-lang.org utilise en ce moment) : je viens de créer un nouveau message, et à cause d’une mauvaise connexion Internet, il n’a pas pu être publié. Il tournait indéfiniment. Après quelques minutes, j’ai appuyé sur F5 pour débloquer cet onglet, et j’ai découvert que les ~30 dernières secondes de frappe avaient été perdues – il y avait un brouillon sauvegardé localement, mais il était obsolète.
Ne serait-il pas facile de mettre à jour le brouillon sauvegardé localement en appuyant sur “répondre” ? J’apprécierais que Discourse puisse prendre en compte les besoins des personnes ayant une connexion Internet médiocre. Actuellement, c’est un domaine où les anciens forums comme phpBB3 font bien mieux que Discourse.
