Categoría pública en foro privado
What would it take to make it possible for a private discourse instance to also have one or more public categories?
A use case would be that the primary purpose of the forum is internal communication in an larger organization but that organization might also engage with a community or the general public and a discourse forum could obviously facilitate that kind of dialogue too. I suppose the current way of doing this is simply to set up to instances, one inward facing and one outward facing, but that would entail quite a high “wall” between those two instances, making it impossible, for example, to quote public posts in internal discussions (apart from referring to the entire post) let alone to move an internal topic into the public forum. Also, employees would have to login to two separate forums which may be confusing for some. - So, in brief, it’s not ideal.
So I’d be curious to hear
  • what kind of workarounds people have developed for this kind of scanario
  • what it would take in terms of plugins or so to either partially drill open a private forum or to make that wall between two instances more permeable.
See also: Public question in private forum
6 Me gusta
Well the way we see it:
Categories = walls
Forums = houses
We generally recommend that if you need multiple houses, create 2 forums. If you just need to wall off content use categories.
In practice we never see this problem, we have 2 instances, meta … and a private home where our internal discussion happens. If we need to quote we can do so fine in multiple ways:
so I end up with a lot of bacon fat: How to make your own bars of soap - #16 by bongly - boing - Boing Boing BBS
Having your houses mixed up is risky business cause you lose out on having a proper safe place where you know that even if you pick the wrong category if you post a topic by mistake nothing terrible will happen.
The extra domain for your private house is a feature, and a great one.
9 Me gusta
Come at it the other way? One of my sites is ‘semi-private’ in that some Categories are restricted to TL0. Works for us.
1 me gusta
Yes, but the problem is (only if that’s a problem, of course) that your membership lists, tags, groups and what not remain public.
1 me gusta
Same need here.
My forum is private clients-only but I’d like to involve also potential customers that can’t read private discussions.
I can invite them and force them to join the group “leads” but I’d like show them a specific category and specific discussions
2 Me gusta
And presumably the ability to see any users profile if you can see their avatar or guess their username?
1 me gusta
Curioso por ver si alguien ha encontrado una buena solución. Tengo una comunidad exclusiva por invitación de profesionales expertos para compartir información sobre lo más avanzado… Me gustaría tener un área pública para que personas no expertas puedan hacer preguntas. No quiero pedir ni obligar a la comunidad de expertos a unirse a otro foro para este propósito.
Tenemos la misma necesidad, pero por una razón diferente. La página de inicio no resulta atractiva si no hay noticias, por lo que nos gustaría mostrar las categorías que tienen los anuncios oficiales que son públicos, pero no las discusiones que están limitadas a usuarios registrados y aprobados. No necesito acceso de escritura allí.
3 Me gusta
¿Alguien ha encontrado una solución para esto?
1 me gusta
7 personas en este hilo, solo 1 voto para la función, ¡vamos si todavía tienen votos! :slight_smile:
Realmente me gusta la idea del grupo de invitados mencionada en este hilo por @Antroden como un grupo restringido de usuarios invitados en un espacio privado donde pueden comunicarse, ver y compartir cosas, tal vez al estilo de SharePoint, con el resto de la comunidad.
Podrías usar formularios de contacto dentro de temas para que los usuarios anónimos hagan preguntas GitHub - jericson/discourse-contact-plugin
Requiere que tu foro sea público, pero con la configuración adecuada podrás ocultar/deshabilitar el acceso a todo.
Si ambos tipos de usuario están registrados, entonces, por supuesto, puedes mostrar categorías por grupo. Pero si quieres que los clientes sean públicos/no registrados, entonces, por supuesto, necesita esta característica (o una similar).
