Herbouw fout - pups?
I rebuilt earlier this week without a problem, but as of this morning I get the following warning. Some help to track down/solve the cause would be great!
cd /pups && git pull && /pups/bin/pups --stdin
From https://github.com/discourse/pups
   4cfff79..dadedef  master               -> origin/master
 * [new branch]      update-test-raketask -> origin/update-test-raketask
Updating 4cfff79..dadedef
Fast-forward
 Rakefile            |  6 +++++-
 lib/pups/config.rb  |  1 +
 pups.gemspec        |  2 +-
 test/config_test.rb | 19 ++++++++++++++++++-
 test/test_helper.rb |  3 +--
 5 files changed, 26 insertions(+), 5 deletions(-)
I, [2021-04-08T07:15:23.054469 #1]  INFO -- : Loading --stdin
/pups/lib/pups/config.rb:23:in `[]=': no implicit conversion of Integer into String (TypeError)
        from /pups/lib/pups/config.rb:23:in `block in initialize'
        from /pups/lib/pups/config.rb:23:in `each'
        from /pups/lib/pups/config.rb:23:in `initialize'
        from /pups/lib/pups/cli.rb:27:in `new'
        from /pups/lib/pups/cli.rb:27:in `run'
        from /pups/bin/pups:8:in `<main>'
b633202aedf2a25566fb21e3f1ff7db418cd2d5fe13835c468914e179f3099e9
I can +1 this, Experiencing the same issue here as well.
I just pushed a fix, can you try to rebuild again ?
Seems to be going past the pups issue now. Would edit this reply if the bootstrap still fails.
EDIT: Built successfully.
The rebuild completed succesfully. Thanks for the quick solution, Sam!
