Recente pogingen tot upgrades mislukt en opnieuw opbouwen ook met fouten
A user, Bathinda, encountered issues during a Discourse upgrade and rebuild, with the process failing due to a database migration error. After troubleshooting, Bathinda resolved the issue by disabling several plugins, including discourse-legal-tools, which was suspected to be the cause. JammyDodger suggested checking the error logs and pointed to a known issue with discourse-legal-tools linked here, which Bathinda found helpful. The issue was resolved by systematically disabling plugins and rebuilding.
In the last 1-2 days, my front end ‘upgrade’ operation got struck and I rebooted the server to fix it, which it didn’t.
Then I tried to ‘Git Pull’ and ‘Rebuild’.
But rebuilding the ‘web_only’ is failing with the below given msg:
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 723 exit 1>
Location of failure: /usr/local/lib/ruby/gems/2.7.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
4454b841c169a9af4f4019b36d647517a711304d2f72a7c8624218f9b883ed91
Kindly somebody guide.
Can you scroll up and check for more specific errors?
Thanks for your kind reply.
Though, I happen to solve this error of mine by disabling these plugins (now I’ll check enabling each plugin one by one):
discourse-telegram-notifications
discourse-locations
discourse-formatting-toolbar
No worries. :slightly_smiling_face: Glad you sorted it so quick. :+1:
I think legal-tools may be the one:
Ah!! That’ll solve lot of my time to consider it each plugin and then rebuild. Thanks ji.
