Hello, this morning my Discourse failed for me mid-usage, and rebuilding has me stuck. Initially I had the “Oops!” page, but after my first rebuild it won’t start at all.
- I’ve removed all plugins, official or otherwise, leaving only docker_manager.git
- I’ve git pulled from within/var/discourseand amAlready up-to-date.
- I’ve tried ./launcher cleanup, but./launcher rebuild appstill fails
The error shown is:
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake assets:precompile' failed with return #<Process::Status: pid 17092 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development --retry 3 --jobs 4'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
f3a13e3833fdc05123d7232621e11b0a0abdcfadad416474f12ee87f319e0f1e
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
Going up, I see a rake aborted! error:
Log
Start compiling CSS: 2019-02-08 20:21:39 UTC
Compiling css for default 2019-02-08 20:21:39 UTC
precompile target: desktop Dark
rake aborted!
ArgumentError: comparison of Integer with nil failed
/var/www/discourse/app/models/theme.rb:132:in `sort!'
/var/www/discourse/app/models/theme.rb:132:in `block in transform_ids'
/var/www/discourse/app/models/theme.rb:88:in `get_set_cache'
/var/www/discourse/app/models/theme.rb:123:in `transform_ids'
/var/www/discourse/app/models/theme.rb:332:in `all_theme_variables'
/var/www/discourse/lib/stylesheet/importer.rb:43:in `block in <class:Importer>'
/var/www/discourse/lib/stylesheet/importer.rb:151:in `instance_eval'
/var/www/discourse/lib/stylesheet/importer.rb:151:in `imports'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sassc-1.11.4/lib/sassc/import_handler.rb:29:in `block in import_function'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sassc-1.11.4/lib/sassc/engine.rb:40:in `compile_data_context'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/sassc-1.11.4/lib/sassc/engine.rb:40:in `render'
/var/www/discourse/lib/stylesheet/compiler.rb:38:in `compile'
/var/www/discourse/lib/stylesheet/compiler.rb:20:in `compile_asset'
/var/www/discourse/lib/stylesheet/manager.rb:162:in `compile'
/var/www/discourse/lib/stylesheet/manager.rb:96:in `block (2 levels) in precompile_css'
/var/www/discourse/lib/stylesheet/manager.rb:89:in `each'
/var/www/discourse/lib/stylesheet/manager.rb:89:in `block in precompile_css'
/var/www/discourse/lib/stylesheet/manager.rb:88:in `each'
/var/www/discourse/lib/stylesheet/manager.rb:88:in `precompile_css'
/var/www/discourse/lib/tasks/assets.rake:60:in `block (2 levels) in <top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rails_multisite-2.0.6/lib/rails_multisite/connection_management.rb:63:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rails_multisite-2.0.6/lib/rails_multisite/connection_management.rb:73:in `each_connection'
/var/www/discourse/lib/tasks/assets.rake:53:in `block in <top (required)>'
/var/www/discourse/lib/tasks/assets.rake:235:in `block in <top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rake-12.3.2/exe/rake:27:in `<top (required)>'
I gather there may be a theme and/or component error, but I cannot enter safe mode to disable anything because my site won’t start at all.
What do you recommend to do next in this scenario?
Thank you.
