עדכון בטא האחרון (קיבלתי אזהרה על עדכון קריטי), עכשיו Discourse לא יתחיל
סיכום מבוסס בינה מלאכותית
WaitroseCarpark encountered a critical error after updating Discourse via the frontend, which prevented the site from starting. The error occurred during the assets:precompile step, with a Pups::ExecError and failed bootstrap. After attempting a rebuild manually, they ran ./discourse-doctor, which seemingly resolved the issue by successfully restarting the app WaitroseCarpark. JammyDodger asked for the version number (edc6b6f26c, 3.3.0 beta 5 dev) and advised checking earlier logs for root causes, noting that the error shown is often a symptom, not the source. WaitroseCarpark admitted unfamiliarity with Linux logs and confirmed the app had started after the doctor run. Firepup650 urged checking further up the logs if rebuilds fail again. Later, WaitroseCarpark successfully rebuilt the site again without issues, confirming stability and thanking the community for support.
I ran update from frontend as I thought it might fix a onebox embedding issue. Thought I’d run a rebuild, just because. But this is the last message:
Hosted with digitalocean.
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'SKIP_EMBER_CLI_COMPILE=1 bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 788 exit 1>
exec failed with the params {"cd"=>"$home", "tag"=>"precompile", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'SKIP_EMBER_CLI_COMPILE=1 bundle exec rake themes:update assets:precompile'"]}
90fa3dc632feafe86edf69feca9c1a1a48f166e6368e6503b5768d01af622f3d
Running ./discourse-doctor just runs a rebuild. I’ve already tried that, but it failed. Anyone else experienced this?
I’m afraid I’m not very au fait with Linux so might need some handholding in what to look for/how to fix.
The rebuild by discourse doctor seems to have fixed it!
Did it rebuild, or did it restart the existing app? What version number is on your dashboard? (The blue number)
Just as an FYI, the errors are further up in the logs, so sharing more of the tail end can help people figure out what the specific problem is.
edc6b6f26c 3.3.0 beta 5 dev
I tried a straight rebuild after the update whereas about 5-10 mins later the site wouldn’t respond to refreshing browser.
So checked CLI and (the above) was there.
After that I ran another rebuild, whereon I noticed the doctor thing, so I tried that.
I did notice that the app had managed to start (although I don’t usually watch it run through) and seemed to be happier when it finished.
I’m afraid I don’t even know how to check the logs to see what it said :grimacing:
If you run another rebuild, does it succeed? If not, please scroll up a bit through those logs for the true errors.
Was brave enough to do another rebuild today (last time was on my birthday and I did not want the grief of having to spend all day fixing it.
Ran fine, didn’t see anything that stuck out as a red flag in the log so happy days!
Thanks for the help.
