Rendering Component in decorativeWidget API
Hello,
I have a component to render ads in my discourse {{numeramaAdsBlock "side_ad"}} and i want to render this component inside the sticky sidebar in a topic. So i use decorateWidget to add my component inside the widget “topic-timeline-container”
export default {
    initialize(container) {
        withPluginApi('0.2', api => {
            api.decorateWidget('topic-timeline-container:before', dec => {
                // rendering my component with params
How can i render my component with the params ? Thanks.
Edit : Up ?
As per above quote looks like component in a widget is not possible. So rendering a component in decorativeWidget API is also not possible I guess.
Humm thanks for the reply
I see this topics.. but how can i “override” this “sidebar” without copiying code or rendering incompatible with a new update ? (Without widget)
There is no solution ?
Thanks
May be you should change your component as widget.
I don’t have any solution right now.
С тех пор это изменилось, поэтому стоит разобраться:
