הגיבויים בערוץ יורדים לראש הטבלה
When I typed a message after it I send another my last message is going to top when it should align on bottom.
It’s delay on desktop? cause mobile version is not like that.
No it’s most likely an issue with your network. Can you repro this all the time?
Hi,
Tried to reproduce this with varying network speeds - does not occur beyond seriously slow speeds. I recommend trying with a faster network as upgrading your instance with more RAM would not necessarily solve the problem.
Port 100mb/s it’s the trouble? thank you guys.
