Problème de limite de réponse
I am running a course on Discourse, and all of my students are suddenly complaining that there is a 'Reply Limit" imposed upon them. I have never had this before? I changed all of their statuses to ‘member’ thinking that was the issue, and then went to Settings/Postings/NewUserMaxRepliesPerTopic and changed it to 100 but they are still having problems.
Any help?
Lee
Are they running up against any of the rate limits or consecutive posts limit?
/admin/site_settings/category/rate_limits
/admin/site_settings/category/all_results?filter=consecutive
Hi Omar,
I changed the Rate Limits so I don’t think that’s the problem.
I couldn’t find this one in admin?
You can search for the term consecutive in the Admin to find it.
Is this it, Omar?
If so, what does it mean?
I have read it and re-read it and I can’t wrap my head around it?
Well, the definition of the word “consecutive” might help:
con·sec·u·tive – following continuously.
“five consecutive months of serious decline”
“share prices fell for three consecutive days”
synonyms: successive, succeeding, following, in succession, running, in a row, one after the other, back-to-back, continuous, straight, uninterrupted
So if someone adds that many replies in a row to a topic (aka consecutively), they will be prevented from adding even more replies until someone else replies.
In other words, this is (generally) a bad pattern for discussions:
Reply #7 Martin words words words
Reply #8 Martin even more words
Reply #9 Martin yet more words
:boom:
You can trust that I know what the word ‘consecutive’ means, Jeff.
I didn’t view the word ‘row’ in that context. I was thinking in terms of ‘rows’ as in the platform.
Thanks for clearing this up.
I will extend it.
Lee
What does that mean?
Well, the definition of the word “platform” might help:
(computing) A particular type of operating system or environment such as a database or other specific software, and/or a particular type of computer or microprocessor, used to describe a particular environment for running other software, or for defining a specific software or hardware environment for discussion purposes. quotations
So the underlying platform for Discourse is made up of Linux running under Docker, Ruby on Rails, Redis, PostgreSQL, and a few other things that I can’t immediately think of. The word “row” is a term of art for SQL-esque databases, so, presumably, that’s a setting for configuring how many replies get stuffed into a single database row.
Touché :wink:
I’m still unclear what one could be confused about, is “consecutive posts” and “posts a user has to make in a row” not understandable?
We can replace it with one or more synonyms if that helps people understand:
Actually, that might make it worse. Under the rule against surplusage, anyone reading that list is going to try to come up with a definition under which all of the given “synonyms” actually mean something different.
If you really want me to try to write a description, though…
Number of posts a user can make to the same topic, without giving anyone else a chance to reply, before being prevented from posting again.
But I’m not sure if that’s better or worse.
I would remove ‘in a row’ and replace it with ‘consecutively’.
For clarification, in your replies, are you trying to make me feel more stupid than I already do? Are you trying to make a joke? Are you serious? I’m interested in understanding the context of your replies.
I can’t speak for Jeff, but I can say that reading this thread it doesn’t come across that he’s trying to mock or belittle.
As terms go, here in the UK ‘in a row’ is a much more commonly used term than consecutively. It’s used in all kinds of fields; we talk about seats in a row, days in a row, personally I would expect more people to know and use that term than to ever reach for consecutive. Both terms appear on the setting, so hopefully people will be able to grasp at least one of them - there aren’t many good alternatives, lest we be reduced to referring to successive or ensuing responses.
Either way, it appears as though you have your solution.
That’s fairly misleading, particularly when there’s no measure of time involved in that setting. Consecutive posts aren’t a rate limit - the setting exists to encourage people to think out their responses and minimise excessive thread bumps. As pointed out earlier the majority of communities don’t encourage such behavior, which is why the default is 3 but it can be overridden if needed.
Not at all, I’m curious how any other interpretation of “consecutive replies” is possible. So you think changing:
max consecutive replies
Number of posts a user has to make in a row in a topic before being prevented from adding another reply
to
Number of consecutive replies posts a user has to make in a row in a topic before being prevented from adding another reply
is the way to go? I was thinking having a synonym in there might be better than repeating the word “consecutive” again?
“successive” I guess does not work cause brain reads “success” but “continuous” kind of works imo if we want to avoid consecutive, however it is somewhat open to interpretation.
Continuous doesn’t really mean in a streak though, does it?
I guess we can wait for now and see if others find the language confusing here as well. I am big on improving copy to make sure things are as understandable as possible by the widest possible audience.
Le paramètre « nombre maximal de réponses consécutives » est-il censé s’appliquer également aux sujets créés par les utilisateurs eux-mêmes ? Pour moi, il ne semble pas limiter les réponses consécutives dans un sujet appartenant à l’utilisateur.
Édition : Je vais utiliser le plugin « no bump », qui est plus strict que la limitation des réponses consécutives : Discourse No Bump
Non. Si vous avez créé le sujet, vous pouvez y répondre autant de fois consécutives que vous le souhaitez. Les propriétaires de sujets sont exemptés de cette restriction.
Comment les réponses signalées/cachées s’insèrent-elles dans cette situation ?
Si un utilisateur publie 3 réponses consécutives, mais que l’une de ces 3 réponses est signalée et cachée avant qu’une nouvelle réponse de quiconque n’arrive, cet utilisateur peut-il publier une 4ᵉ réponse ?
