استعادة نسخة احتياطية من Discourse 1.9 إلى v2.3.0.beta9 +184
ERROR: cannot drop table users column email because other objects depend on it
DETAIL: trigger users_email_readonly on table users depends on table users column email
HINT: Use DROP … CASCADE to drop the dependent objects too.
So the docker install discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub install the LATEST… how to select a stable version?
Downgrading isn’t supported, you can’t roll back to beta or stable until they pass the current tests-passed. You can use the commit ID as per this topic, but it’s very unlikely a routine upgrade is the cause - Discourse isn’t prone to spontaneous combustion.
Do you have sufficient free space on the server? Have you disabled all plugins and re-tried?
OP is trying to restore a backup with a schema from 2017 so this is not what he is trying to do.
Might this be related to the fact that delayed column drops are working differently nowadays?
Fair enough, I was going by the title, which said he was upgrading to beta9 +184.
Yes I was using v1.9 earlier and now I was planning to upgrade to v2.2.
I switched from Bitnami to a dedicated Docker install. Somehow latest+latest was installed. So I got v2.3.0.beta9+184 where the backup import failed.
So have to look up how to install a specific docker version
Might be similar to this Trouble upgrading from 1.9.0.beta11
إعجاب واحد (1)
Yes! The solution basically is:
to avoid this just run db:seed_fu before you backup or upgrade Postgres
إعجاب واحد (1)
