/review/settings אפשרויות לא נשמרות לאחר רענון דף
Hello,
I have a feeling that this is a bug unless it is based off this setting reviewable default visibility which I don’t think it is.
If you go to https://your-site-url/review/settings the default is set to low
To Reproduce problem:
  1. Change the option to High or Medium for example and press Save Changes
  2. Refresh the page and the options will all be on Low
Expected result: When you press ‘Save Changes’ the options chosen save
Actual Result: After pressing ‘Save Changes’ and refreshing the page options don’t save
2 לייקים
I can reproduce this on my local dev site and on my hosted site. After updating the Reviewable Priorities from the review/settings page and then refreshing the page, none of the changes are saved.
לייק 1
This has recently regressed. We clone the review settings but use the original when trying to save them. I made a PR to fix it:
https://github.com/discourse/discourse/pull/11125
5 לייקים
This topic was automatically closed after 29 hours. New replies are no longer allowed.
