Sam's Simple Theme
The latest update seems to have caused a lot of clutter on mobile.
I don’t believe I have any components which would cause this to happen.
Anyone else encounter the same?
Same here. As I remember, the theme was not applied to the mobile version.
Thanks for reporting it, this should be fixed now if you update again.
Awesome - thank you very much!
Hi there, with the upgrade to 3.4.0 unfortunately Sam’s Simple Theme is a bit of a mess:
Is moving the op-data to the top an intentional change? It seemed much more compact and space-efficient the way it was before.
I should also just mention that I am very thankful for Sam’s Simple Theme. When I migrated my large forum to Discourse my users absolutely hated the default Discourse theme, but they found Sam’s Simple Theme layout much more acceptable, so thanks for creating and maintaining it, it’s a key component for me to make Discourse viable.
Thanks for the feedback! I’ve adjusted this to put the metadata on the same line again and fixed the icon wrapping issues
Awesome @awesomerobot , thanks so much!
I don’t suppose there’s any way the fix could be backported to the stable branch? I would just apply your CSS changes to a custom theme component, but I see that there are also changes to original-post-date.gjs .
I don’t quite understand why I’m not getting the updated version from the main branch of GitHub - discourse/discourse-simple-theme: Sam's simple discourse theme. The theme updater hasn’t found any new versions and I still have the layout issue.
Check, I’m on Discourse v3.4.0 +4
Is it a dependency issue?
Versions less than 3.5.0.beta1-dev are pinned to a previous commit, because commits after it are incompatible with previous versions. So unfortunately you won’t get new commits until you update Discourse.
