{{tag-chooser}} is making a call to /tags/filter/search
when you gain focus on the input, or use the filter.
The thing is that even if sending an array of selected_tags
when no q
is given, it will always return the same 5 tags:
which explains why in this screenshot I have only one tag possible when there are a lot more tags possible.
It’s not an extremely important issue, because as soon as you start typing to filter you will receive an appropriate list, still we should probably want to fix it at some point as it’s kind of unexpected and also hurts a little bit tag discoverability.
