Seeing two banners for subcategories
I have subcategory banners using the category banners plugin, however I’m also seeing a ‘category heading’ which includes the same information, only on subcategories. I’m not sure why the ‘category heading’ is only displaying on subcategories and can’t find a setting to remove it.
I would like to keep using the category banners plugin. I think this would be easy enough to fix with css but wanted to check if there was a setting / this was a bug first.
https://community.bookbrowse.com/c/book-clubs/mercy-by-joan-silber/74
The white banner is created by Discourse when you add a category logo in the image settings of the category.
Unfortunately, this banner isn’t hidden when you enable the category banners component.
This was reported before in Default category heading not hidden when category banner is used
In the second post of that topic, you will find CSS to hide the default banner on your forum
If you update the banner component the default banner will now be hidden, I’ve just made an update — thanks for reporting it!
