הצגת תגובות באותו מקום כמו Reddit, במקום להראות אותן למטה
סיכום מבוסס בינה מלאכותית
Conmajia is looking to implement a feature in Discourse where replies appear “in-place” directly below the post they’re responding to, similar to Reddit’s format. Moin suggests that while this exact feature isn’t available, Discourse does allow expanding direct replies to a post at its bottom. Moin also shares a blog post and a meta discussion link that might be relevant to Conmajia’s inquiry, which Conmajia finds helpful.
Hey everyone!
Just wanted to drop in and say I’m super excited to be part of the Discourse community! :heart_eyes:
I’ve been poking around in the settings and I wonder if there is a way to have replies show up “in-place” right below the post they’re responding to, instead of staying at the bottom of topics?
I noticed that Reddit does it like this:
The replies are connected to the post they’re replying to and you can expand them right there.
Any thoughts or ideas on how to do something similar in Discourse? Would love to hear your input!
:saluting_face:
Maybe you are interested in Web Discussions: Flat by Design
But you can still expand direct replies to a post at its bottom. So below your post, you see an indicator about my reply, and you can read it right there, even if there would be other posts in between. By default, some of these indicators are suppressed, but you can adjust the settings to fit your needs.
You should also take a look at Discourse Post Voting
Great hint! Thanks!
