Anmeldeerinnerung?
Hello,
how can i aktivate the sign up reminder?
And how i can change the Text ?
You can read about the conditions at
You can alter the text by going to Admin > Customize > Text Content, search for cta
Should activate that. To edit admin>customize>Texts
Edit this to change it.
Is it possible to preview the changes that I’ve made? I want to make sure that my references to categories are formatted correctly in this instance.
This is one of the reasons we regularly find ourselves recommending small secondary instances, to test things before altering your live environment.
Assuming I’m using a secondary instance then, is there an easy way to see a preview? Having to replicate a new user’s behaviour in order to see it is a little bit time consuming.
You can change the values in localStorage from the JS developer console.
