Hi,
If a topic has a short content, the message admin options are partially hidden by the header:
The discussion revolves around an issue with the site header overlapping the message admin options on the forum. Canapin reported the issue and provided a screenshot. itsbhanusharma suggested trying safe mode and checking for rogue plugins, but was unable to reproduce the issue. After Canapin clarified the issue, itsbhanusharma still couldn’t reproduce it, but eventually confirmed the issue after Canapin pointed out the difference between topic and message admin options. itsbhanusharma identified the issue as a CSS problem and tagged @Johani. awesomerobot discovered that the issue was caused by translated text wrapping to multiple lines, making the menu taller. A fix was proposed by awesomerobot, setting an auto width with a max-width of 320px, which should be available within a day, addressing Canapin’s suggestion to set a fixed width with a max-width.
Tried in safe mode? can be a rouge plugin!
I corrected my topic : the menu is not the topic options, but the message options.
I tried in safe mode as well.
This is something with CSS! I can confirm the Repro Now!
cc @Johani
Ah I see, the translated text is wrapping to multiple lines so the menu is taller than it is in English. I should be able to change this so the buttons are wider instead of wrapping, which would make it short enough.
You’ll set a fixed width, not an auto width (with a max-width just in case)?
I took a look and ended up setting an auto width with a max-width (max-width is 320px, which is generally the smallest mobile screen we support). This change should be available within the next day.
This topic was automatically closed after 5 days. New replies are no longer allowed.
