2.3.0 beta 5 后站点无法构建
I opened an issue earlier, but unfortunately it was closed before it was resolved:
https://meta.discourse.org/t/site-not-building-after-2-3-0-beta-5-update-unless-i-disable-discourse-solved-plugin/111737/3
The issue is that the new Discourse version does not resolve unless Discourse-solved plugin is disabled. I found the error:
StandardError (Attempting to access a non preloaded custom field, this is disallowed to prevent N+1 queries.)
/var/www/discourse/app/models/concerns/has_custom_fields.rb:158:in `
Here is the link to the rest of the error log (let me know if I am endangering my site by showing this…I could not find anything that looked sensitive, but then again I am not a hacker)
Did you get latest and rebuild as requested?
2 个赞
To my knowledge, yes.
Any idea here @vinothkannans?
1 个赞
I have rebuilt, cleaned, updated, upgraded, rebuilt, cleaned, enabled, dis-enabled…I’m not sure if there is another command I can run to tune up my install.
1 个赞
I completely rebuilt the site 5 minutes ago and additionally installed it again on the computer (with the Discourse-solved plug-in). Strange, but I have no errors, everything works (in both cases). As I wrote earlier, I cannot repeat the mistake. (
1 个赞
I will disable every plugin, except the solved plugin and report back in 10 minutes.
1 个赞
I am in the middle of a rebuild, but it occurred to me that one thing I have not tried is to disable/remove the theme (Material Design Stock Theme). I suppose I can try that as well since that is another variable unique to my install.
Hooray, the rebuild worked with only the solved plugin and docker manager plugin. I will enable each plugin, one by one, and rebuild in between. I will then report back.
It looks like it broke again after I enabled the discourse-locations plugin. The only three plugins enabled now are docker manager, solved, and locations.
https://solvecrimeinrealtime.us/logs/show/96bf242f6d353223809eb4b17ea6f16d
3 个赞
So file an issue on that plugin, it is third party.
5 个赞
Will do…thank you! Problem solved. I really appreciate your patience with me on this. Thanks again.
7 个赞
Yes, the issue is coming from the “discourse-locations” plugin. But this is related to the recent changes in solved plugin to prevent N+1 queries. Currently locations plugin also having the N+1 issue. I will make a proper way to include category custom fields in site serializer. Then @angus have to change the locations plugin code according to that.
5 个赞
