Site not showing after following official installation walkthrough
Joe_Perkins encountered issues with their Discourse site not loading after following the official installation guide on Digital Ocean, with the subdomain talk.landscape.ventures redirecting to an unreachable IP. Arkshine suggested checking DNS configuration and propagation. Joe_Perkins later resolved the issue, attributing it to two factors: the droplet size being only 1GB (insufficient for Discourse) and an improperly configured SMTP account with SendInBlue. Switching to Mailgun resolved the problem. Stephen noted that 1GB RAM is sufficient if swap is properly configured, indicating the issue was likely related to the SMTP setup rather than the droplet size.
Hey guys, really excited to get set up with Discourse, but run into a problem whereby my site just doesn’t load.
I have followed this walkthrough on Discourse GH to set up using Digital Ocean.
The domain I am using was purchased and managed at GoDaddy, and currently it is displaying a site hosted on Webflow. I created a subdomain on the godaddy site by adding an A-Name record that points to my DO Droplet ipv4 address.
When I run ./discourse-setup, I answer all of the required settings, and skip the LET’S ENCRYPT email.
Everything appears to run through over the course of 5-10 minutes, with no errors, however once the script has finished, and I navigate to my subdomain address, it seems to redirect it to a different IP address (not the DO droplet id), saying it cannot be reached.
Any help on this would be massively appreciated, the subdomain I am trying to set up is talk.landscape.ventures
Thanks in advance
It would seem talk subdomain is not created (yet?).
I would double-check first on GoDaddy that everything is configured/saved as expected.
If so, it could also simply means that you have to wait until the DNS is propagated, but I don’t think that is the issue here. Because we should already see responses from different servers and currently talk doesn’t exist.
Thanks for your response, I really appreciate it.
In the end this was being caused by 2 issues:
  1. My droplet size being only 1GB not 2GB
  2. My SMTP account hadn’t been set up properly with SendInBlue. As soon as I switched to Mailgun which gave me an instant SMTP address, Discourse ended up installing correctly.
1GB is fine providing you configure swap. RAM isn’t a problem.
